Do you know if there is supposed to be a gasket between exhaust pipe and the engine on the BV350 ST? I would imagine normally there should be one. If that's the case it looks like it's missing on my BV (see attached photo, circled red). Does this look similar on your scooter?
The reason I checked this was that I started hearing unusual noises when accelerating which sounds to me like I have a leak in the exhaust. After checking the pipes this looks like a potential source of the leak as everything else is tight.
Many thanks.
