@basherburton avatar
GTS 300 Super
GTS 300 Super
Hi all, just signed up to MV today so this is my first post. Anyone know what this 2wire connector(black & black/yellow wires) is for? I havent metered it out yet but I suspect it may be a running light feed , can anyone confirm?
@dongyerscoot avatar
Vespa 300 GTS
Vespa 300 GTS
Was wondering that too! Mine is near the front right turn signal,,,
Popcorn emoticon Nerd emoticon
GTS 300 Super
GTS 300 Super
I'm gonna get my test meter on it tomorrow. I'll post the results on here pal
⚠️ Last edited by basherburton on UTC; edited 1 time
Vespa 300 GTS
Vespa 300 GTS
basherburton wrote:
I'm gonna get my test meter on it tomoorow. I'll post the results on here pal
I'm sure some peeps will chime in? Welcome to the group!
Scooter emoticon 8) Crying or Very sad emoticon Laughing emoticon Clown emoticon
GTS 300 Super
GTS 300 Super
Cheers pal
@ridinhigh avatar
vespa gts 300i super
@ridinhigh avatar
it could be the wires for a 250 running light,i put a 25o horncast with running light, on to my 300,using those wires
,also you might have wires spare for the alarm ,but they usually go to a white plug
⚠️ Last edited by ridinhigh on UTC; edited 1 time
@rkcoker avatar
Piaggio BV350
@rkcoker avatar
Piaggio BV350
Just guessing here, but could those be be for the US DOT turn signal lights?
They are for those GTS models with a running light in the horncast.
@ridinhigh avatar
@ridinhigh avatar
Thanks Jim
i used those for the light in horncast when i sold scoot ,the buyer thought at first it was a 250,
but then thought it was a great idea,different
Vespa 300 GTS
Vespa 300 GTS
I measured 2 volts coming out of it when the key in the on position.
So how much would be good to hook up to it, just anything not over 2 volts and should be fused? If they are led, they would need those resistor things?
Hmmm..
Vespa 300 GTS
Vespa 300 GTS
It looks like they used the same harness for the scoot that uses this light:
Wha? emoticon
GTS 300 Super
GTS 300 Super
DRL's fitted for the princely sum of £3 (courtesy of the 'Bay (item number: 251714438606)) using the Horncast 12V light feed( only on when ignition is on) on the GTS300S
Pics to follow( if anyones interested?)
Probably spent a total of 2hrs from conception to fruition so all in all I think 2 hrs well spent and DEFINITELY increased my visibility to other road users.
@smu avatar
2014 Primavera 125 3v
@smu avatar
Sure, go ahead. Always nice to see a safety mod.
Vespa 300 GTS
Vespa 300 GTS
I was not able to use it, even made a custom connector. The ground I used maybe did not work? I just used the stock alarm connector leads. I added auxiliary headlight, not wired up yet.
GTS 300 Super
GTS 300 Super
Mk I ...... taped in place, just read up on DRL specifications and they SHOULD turn off when indicator comes on, HOWEVER, mine are always on when ignition is on .... i think its gonna have to be a REALLY bored policeman that pulls me for it!
Vespa 300 GTS
Vespa 300 GTS
That looks nice and noticeable!
Whew emoticon Clap emoticon
[ Time: 0.0149s ][ Queries: 4 (0.0038s) ][ live ][ 341 ][ ThingOne ]
