Re: P2 lump rebuild/reassembly. again.
macgerk77 wrote:
I'm needing to install a new crank in a P2 motor, but the fly side inner bearing race is stuck on the old crank. any thoughts on the best way to get that sucker off there?
factory puller.
of course, for the cost of that tool if you're only going to use it once you're better off just buying a new $13 bearing and installing that on the crank and not reusing the old bearing.
