Posts: 5109 Location: west aus |
8-battery tray
10-clutch 4-fuel line 1-frame next to cylinder Will have another look on computer after work for the rest |
Vespa P200, Primavera 130, VNA200, Italjet Pack-a-Way Moped, Ciao etc
Posts: 322 Location: Humboldt County, California |
Okay, I'll play...
I can only get a few...
10- goes over rear brake cable as it exits tub3 from body heading to pedal, 7- fuel line grommet, 1- i think is wiring harness thru frame into engine bay, 2- is related to the coil or lt wire to the coil. Wish I could do more. |
1. Under frame cable grommet
2. Stator wire case grommet. Small frames and early 1970s large frames with two holes in stator well. 3a. Horrible picture 3b. Horrible picture 4a. Horrible picture 4b. Horrible picture 5a. + 5c. Both are frame grommets for wiring. 6. There should be 2 of them. They are rubber buffers for under a P-series seat 7. Frame grommet for fuel line. 8a. + 8b. Buffers for a leg shield mounted glove box (P-series or small frame). 9. Top buffer for the P-series front shock/damper 10. Grommet for where rear brake cable passes through frame at rear brake pedal on non-P-series large frames. Belongs in trash. 11. Horrible picture |
Was this part of a rubber kit for a particular scooter. I bought a kit last year and I had extra grommets that didn't go anywhere.
RIP
T5s
Posts: 17005 Location: The West Of Yorkshire ... Gods Country |
blanks
a terrible sideways pic of some repop rubber ...... bet 7 is a twat to get in the frame n then get the pipe through ... italian ones are hard enough
joshzingzing wrote: 8-battery tray 10-clutch 4-fuel line 1-frame next to cylinder Will have another look on computer after work for the rest |
joshzingzing wrote: joshzingzing wrote: 8-battery tray 10-clutch 4-fuel line 1-frame next to cylinder Will have another look on computer after work for the rest |
rally 200 electronic vespino 50 s sprint 150
Posts: 9 Location: corfu greece |
1 is under the body right side
2 and 3 as the others said. 4 is for large frame.small metal parts at the rear on side panels 5 no idea 6 p series seat 7fuel line 8 small holes on frame wings where side panels springs are pressed against 10 is cluthc cable |
