2006 200gt
2006 200gt
Hello everyone. I'm new to the forum and new to scooters. I recently purchased a 2006 gt200. It was running a little rough, so I took the carb apart and cleaned it up. It helped out a lot but I noticed that the accelerator pump was wet around the shaft at the rubber boot. So I figure I should change it out. My problem is I cannot find a place to buy this part. Even the Keihin website has let me down. Can anyone help me out?
@scooter_west avatar
Sponsor
Sponsor
I've not seen those available new. We do have a used one if that suits your fancy,
2006 200gt
2006 200gt
Wow! Are parts always this difficult to find?
2006 GTS 250ie
2006 GTS 250ie
Try Af1 Racing:
https://www.af1racing.com/store/Scripts/prodList.asp?idCategory=2682
Select the link to your 2006 GT & find the part in that spare parts catalogue.
https://www.af1racing.com/store/ProdImages/st3/EVG2000US2.pdf
Try page 31. There is a acceleration pump kit listed: CM156708 It is described as a complete float chamber when checking for part availability.
https://www.af1racing.com/store/Scripts/prodView.asp?idProduct=31810
You should be able to find other suppliers by searching the site.
2006 GTS 250ie
2006 GTS 250ie
Here's another site to try:
https://scooterpartsco.com/vespa-parts-by-model/gt-200
Hope you find what you need.
Sponsor
Sponsor
No, in general parts are not hard find. Just accelerator pump bellows for some reason (and float bowl gaskets too, take care of the one you have). I left a bellows on my desk yesterday in case you wanted it and didn't want to spend $96 on a complete float bowl that sometimes comes with a bellows and sometimes doesn't. I'll be back Monday.
2006 200gt
2006 200gt
Seems like you could buy some type of replacement carb for $96.
@mjrally avatar
@mjrally avatar
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
If you are looking for the black rubber bellows like in the photo below, you can get them from any Harley-Davidson dealer. They used Keihin CV40 carbs for years. I used the bellows from a CV40 on another members GT200 about four years ago.
-craig
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
Used maybe, but not new.
-craig
2006 200gt
2006 200gt
-craig
I'm looking for the whole pump since it seems to be leaking from the shaft under the boot. I'm not sure if it can be fixed or not. There must be some type of seal but I'm not sure if it can be replaced.
2006 200gt
2006 200gt
Hey Max, are we talking about the whole pump as shown by Craigs picture? I was on your website before I posted and I did not see this part. I would also like to talk to you about this whole Vespa key thing. Robert
2006 200gt
2006 200gt
Fin wrote:
Try Af1 Racing:
Thanks for all the links.
Sponsor
Sponsor
The complete accelerator pump is only sold with the complete float bowl. There is an oring on the base and a bellows on the top. I'm thinking replacing the oring might solve your issue. Call or email about keys.
2006 200gt
2006 200gt
-craig
My accelerator pump is leaking under the bellows at the shaft. I read in another post that you said it was an easy fix, just change the diaphragm and seal. I'm not sure I understand. I cannot see what seals the shaft as it is compressed into the lower case of the carb. If you could explain I would appreciate it.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
If you are actually pushing fuel past the accelerator pump position (the silver colored part in my photo above) I would suspect two possible problems.
1) the tiny passageways leading from the accelerator pump to the throat of the carb are plugged. When the piston moves, the fuel has nowhere to go but past the piston and the bellows. In the photo below the accelerator pump nozzle is circled. When you twist the throttle you should get a strong spray off fuel from the nozzle. If not the passages or nozzle are likely plugged.
Or
2) your accelerator pump position is so worn that the fuel just passes freely past it and leaks out the bellows.
There is no real "seal" in this design. #1 above is the most likely scenario. The float bowl and carb body need to be disassembled and soaked in carb cleaner for a week or so. Or ultra sonic cleaning is faster.
-craig
2006 200gt
2006 200gt
Or
Thanks for responding Craig. I'll take it off and get it soaking. I appreciate your help.
-craig
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
For clarity... In my last post there are a couple of place where I wrote "accelerator pump position". That is an auto correct error. It should have read "accelerator pump piston". Don't want to confuse anyone with the terminology.
-craig
⬆️    About 8 years elapsed    ⬇️
GT200
GT200
That was so helpful to know! Nowadays you can get a CV40 rebuild kit on Amazon for $13 and indeed includes the below.
Thanks Craig
-craig
[ Time: 0.0301s ][ Queries: 4 (0.0228s) ][ live ][ 318 ][ ThingOne ]
