Px - sprint - lambretta li
Hi all have a new problem my Vespa sprint has a bad miss fire the points are spot on 0.40 fuel flow good was running really we'll put it away two weeks ago got it out to day will not run just back fires
Could it be the condenser
@starreem avatar
@starreem avatar
In my experience, backfiring is usually a timing issue. Check your woodruff key is still in one piece, and the flywheel is mated up properly to the crank.
Old douglas ..smallie with polini 115..super with nasco 177
It smacks of condensor issues
Assuming the wood ruff key is sound then its the Condensor.Take a photo of the junction box connections..Pull the entire stator out on the bench..and also replace the points at the same time Good luck
[ Time: 0.0085s ][ Queries: 3 (0.0023s) ][ live ][ 343 ][ ThingOne ]
