Hi Friends,
I posted several weeks ago about a problem I was having with my 2012 GTS (5000 miles). Well, it has become a bit of a nightmare. Initially, I would be driving and when I hit the throttle, the engine would die for just a bit and then come back. The second time, I was merging onto a busy highway and it was scary. Several of you posted tips, including the possibility of a bad wire to the spark plug. Needing its pre- winter oil change, etc anyway, I drove to the dealer in Northern Connecticut. They looked at it but couldn't find anything; said they test drove it and no problem. I picked it up and about 5 miles from the shop, it pretty much completely died. I could start it, but it would always stall out. Yellow engine light and red code light. They sent out a trailer to pick it up and a week later called and said the "Intake Fitting With Depression" (877930) was warped. They ordered the part and replaced it. Test drove it with no problem. I picked it up last Friday in lovely sunshine and warmth. It did the same thing about 6 miles out. Cruising along at 45, flat road, even throttle. It would die for a few seconds and then come back. Limped back to the shop. I think they are a bit out of their depth, as the tech only has limited Vespa experience. I need to get it back and am thinking of trying the Vespa dealer in Schenectady. Original dealer called Vespa tech rep, and they offered no support. Even though the scooter is not officially part of the fuel pump recall, I am wondering if any of you think that might be the problem. And I still haven't had them replace the wire to the plug. / This whole thing is seriously bumming me out, and I am hopeful some of you might have ideas. Thanks so much. Jon
