Hi guys my little lx won't start any ideas?
Starter motor is turning,plug was wet as if I'd flooded it,cleaned plug still won't go
Help please??????
nifty 50,Honda Dio,tgb,piaggio zip,Vmoto Monza,LX50,GT200l,PX200
Posts: 183 Location: queensland,Australia |
Starter motor is turning,plug was wet as if I'd flooded it,cleaned plug still won't go Help please?????? |
Posts: 12026 Location: Hermit Kingdom |
So your spark was wet from fuel? No issue there then.
The only other things you need is air, compression and a spark. Check the spark plug and your leads and also check the battery as mentioned. Also clean out the air filter if it hasn't been done in a while, might be struggling to breath. If the problem keeps coming back its more than likely ignition. There's a few other things it could be, but id start there Also, is this the fuel injected model or carb? Good luck! |
Thanks guys,battery almost new going to clean air box in morning
It rode to work and back fine this arvo???? Guessing carby model she's an old 05 model |
Ahh yes she will be a carby. Maybe its time to inspect the carb. Sounds like something is getting the float needle stuck in the float bowl causing your temporary flooding issue. But I own an injected bike and could be talking out my arse with that one
Anyhow.., if the air filter looks good which it probably is if you're running fine, then id suspect it to be carb related. |
RIP
Ya know i think they do it to bother us. Mine has done that and there is no reason why it doesn't start (no wet spark plug tho). I know this sounds screwy but i had my mechanic check the bike out after it wouldn't start and he couldn't find anything. Could of been a loose spark plug. Was it wet from gas or water?
