(to keep Dr Google happy yes this is a repost of what is on my blog at http://technicalnotebook.com/non-tech/petrols-other-than-95-ron-for-piaggio-bv350-beverly-scooters/ )
Anyhoo I thought I would throw this here as a bit of a discussion topic for the happy group of us that own Piaggio BV350s.
As I am planning a trip through country NSW and country Victoria here in Australia in a few months, I have been researching what petrol I am likely to have access to. Unfortunately however, for the Australian BV350s, the manual only specifies 95 RON/octane (premium) petrol, which is often not available in country towns.
Therefore I had to contact the local importer for a bit more detail. I thought I would share what they have said so that hopefully it may help others figure out their options when they are unable to source 95 RON petrol.
Thanks for your message. 95 RON is the recommended minimum octane rating. Most fuels identified as "premium" are 95 RON and are widely available. Higher grades such as any 98 RON Vpower / Ultimate / Vortex etc. are perfectly fine and fuel with some ethanol is even acceptable provided it has no more than 10%.
You can use 91 RON if that's all there is provided the bike is not too heavily loaded, however you should top up with premium as soon as it's available. Prolonged use of fuel with an octane rating below the recommended level can damage the engine, particular in hot conditions, and/or when the engine load is high.
Also remember to check your coolant and oil level regularly when travelling long distances. The oil level check must be made with the bike on the centre stand after the engine has been stopped for 5-10 minutes. The correct level is seen when the stick is screwed all the way in. Do not over-fill. The level must be between the upper and lower marks on the stick.
It is good to get some actual hard information on what will happen if you do get stuck in the sticks and can't get 95 RON. Also, with that information now in mind, I think a simple octane booster would suffice if having to use 91 RON just to bring it up that bit higher at a pinch. Has anyone had any experience with these before/any you would recommend?
I hope this helps someone else out, obviously if you are international I would always recommend you check recommended fuels with your local importer *JUST* to be safe (haha have to cover myself there).
Stu
