Like other members has stated:
-Measure your compression (100psi or lower you will need new piston rings).
-Check that your kiil switch is not grounding out somewhere. Is this a points or CDI scoot?
A new cylinder head will not solve your problems. Also check fuel flow, spark, timing. Some people have sheared the woodruff key on the crankshaft and it messes up your timing.
Its not hard to pull the cylinder off. Inspect the bore and piston for wear. Check your piston ring gap.
You may be able to get by with a light hone and new rings to get compression up but if your cylinder and piston are worn its time for an overbore and new piston. It may be cheaper to get a new cylinder kit depending on the machinist's fees.
What ever route you go, check the clearance on the piston/cylinder bore and piston ring gap.
Have the machinist make sure the piston to bore clearance is at a min of 3.5 thousandths of an inch (0.009mm) or you can experience a 4 corner seizure when the piston get up to temperature.
You can measure the ring gap by yourself with feeler gauges. 0.25mm is about right... no smaller that 0.2mm and no larger than 0.5mm. I also measure my ring gap just above the exhaust port.
Good luck.
⚠️ Last edited by mr.j on UTC; edited 2 times
