@curtbull avatar
2013 Vespa Lx 150 ie
@curtbull avatar
I installed an 2013 LXV engine and wiring harness on a 2007 LX 150 Frame, I am finding out that the wiring harness connection on the speedometer/dash area does not match up, Any suggestions for a solution? I have the old wiring harness from the 2007 LX 150 , is it possible to convert the the 2 harnesses or splice the connections I need to match the LX 150 set up?
Crying or Very sad emoticon
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
Yeah.
Take a good look at the 2 harnesses, might luck out and wire colors are same for same functions, would then just need to splice the LX connectors. Failing that will need to study the 2 wiring diagrams, LX one is in the Wiki, may have to do some digging for the LXV.
http://www.wotmeworry.org.uk/manuals/circuits/
skipper st125
skipper st125
Hi
Sorry to butt in on your thread.
What is the difference between a lxv and and lx?
I have an lx engine which has a fuel injector.
I dont want to use the fuel injector (i think).
So i will need a new wiring loom.
I am planning on using the engine in a et2.
Are the connector blocks from the stator/generator the same on both looms?
Thank you
Robbie
@scooter_west avatar
Sponsor
Sponsor
The LX and LXV would be very different at the headset including speedo and switches. I would look for wiring diagrams and see what you can splice or match up. There is no solution I can give in a few sentences. An 2011-2014 LX150 harness would be a lot easier.
wreckless robbie wrote:
Hi
Thank you
Robbie
Do they use the same stator? If not, no.
@greasy125 avatar
@greasy125 avatar
Hi
Thank you
Robbie
if you have an ET2 you'll need a complete harness out of an LX150 or ET4 to make the swap-- no matter if you're going fuel injection or carb.
-g
skipper st125
skipper st125
Yeah I know I will need a new wiring loom.
I think if I need to go carb, I need to change the stator and fly wheel. unless someone knows different. I will then get a new wiring loon.
I have also been told I will need a new crank. Not sure on that one.
Robbie
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
skipper st125
skipper st125
OK thank you for the link.
[ Time: 0.0139s ][ Queries: 3 (0.0018s) ][ live ][ 343 ][ ThingOne ]
