Dahoum wrote:
Hi dawale,
Was the bike on the street or visible from the street. (I'm in W.London and about to get a Vespa)
Hi Dahoum, it was parked behind the 5ft wall at the front of the terrace house where I live. Obstructed but visible. It was almost certainly marked and then they came back for it knowing what needed to be done, I'd say.
I do regret not going to town even more on security and was going to when I had more money. If you can don't scrimp - you'll just kick yourself if you end up losing a scoot by being overly thirty on this.
Highly recommend jamesUK's post from June (https://modernvespa.com/forum/topic139826.3):
"I have a 5 metre long Pragmasis Protector 16mm chain and it's the ultimate chain, the Pragmasis chains are even stronger than the almax chains, anyway.....
The pinch pin works well and if you use it make sure it's through the "rear" wheel and not the front as locking the front wheel is pointless
as all they do is remove the front wheel and bolt another one on.
The way I lock mine up is like this, I run a Kryptonite Fahgettaboudit Mini lock which is 18mm thick through the rear wheel and I feed the lock
through one of the links on the chain which it wrapped around the lamppost, that way it's bolted to something solid.
Then I put an Abus Extreme 59 lock through the front wheel, but I feed the abus lock through the top of the front wheel so it feeds through the forks so that way
they cant even remove the front wheel as the wheel is locked to the forks.
The thing is love about the Kryptonite Fahgettaboudit Mini is that it's 18mm thick and any links 16mm and over can not be cut by bolt cutters even the 5ft ones,
the only way to cut it would be via an angle grinder which makes noise. Also when you run the kryptonite Fahgettaboudit Mini through the rear wheel it's fits so snug and tight
as it's a small lock so you cant get anything into to open it, I can just about feed a link from the chain through it.
You hear so many people talk about there GTS being stolen and there chain was cut, well you can bet it's because the chains links are to small, most chains even the claimed
heavy duty chains are around 11-13mm thick and 5ft bolt cutters would cut them like butter, the key rule is you have to go 16mm and above when it come to chains or a link on a shackle.
The key thing to remember with locks/chains is when you buy a chain or D-lock you want it to be 16mm or over as handheld boltcutters wont cut anything over 16mm, the only way is via an
angle grinder or by using a plasma cutter of some sort.
Here are a list of the best locks/chains you can get for the GTS, yes they can cost a lot but i'd rather have them than have no scooter.
All these Oxford lock/products that are sold to the masses via your big motorcycle stores are crap along with disclocks as one hit and they just pop off as the pins inside them are to small only 6 or 7mm.
1: Kryptonite Fahgettaboudit Mini 18mm (rear wheel) (evens cycles £62)
2: Abus Extreme 59 u-lock 19mm (front or rear wheel) (Amazon £96)
3: Pragmasis chain 16mm or 19mm
4: Abus chain 16mm or 19mm
Where I live in London I see people all the time two up on other vespa GTS's driving up to my scooter to try and steel it and everytime I watch them through the window
and once they see the locks the just drive off, I have seen first hand people eye up my GTS over 20 times and I see them pointing and looking at the locks then they drive away.
On a side note: With The 16mm chains being so thick you can only just about get one link through the rear wheel, the chain will not feed all through as it's to big."
