hibbert wrote:
check the slide. Take off the air filter and make sure the slide can close all the way. Maybe the throttle cable is keeping it from closing all the way. The idle adjustment screw should allow you to open the slide for the correct speed.
just checked that out hibbert. thankfully I think this is the problem, I unhooked the throttle cable and started the bike, it resulted in a low idle. I then rehooked the cable and lubed the slide up some, and that helped, however I think the slide may be tired, or maybe there is a tired spring that needs replacing.
so now that I believe this to be the problem, where do I go from here? full replacement, or a couple new parts? thanks for the help!
