I bought a too cheap to be true Piaggio X9 500 2003.
It has the brown key only and it makes a very unusual pattern on the immobilizer light.
You can see it here: https://youtu.be/FaX78EwGp5M
I know that there is a X9 forum but it is not working now, so I want o ask you if someone has solved a problem like this.
The pattern is 1 long , 2 shorts, 1 long and then the light remains on. The starter motor works but the engine doesn't start.
I have read the post on the different lights patterns and this is different.
I hope you can help me. Thanks
