I have a vespa GTS 2007 that has stalling problems when hot. Also feels boggy occasionally, but, again, only when hot. When it stalls out it keeps running until the RPMs go down, but barely and with no rev, until it stalls. It only starts up again after 5+ mins when cool. If I hit the throttle too hard right after this it stalls again and I have to wait another 5+ minutes. If the temp is 80+ degrees itll happen. If its 70 or so, like when I go to work in the am, it never happens.
It seems like a common issue but, unfortunately, the 2007 models were not part of the recall.
So, I am looking for a tutorial on how to get at and replace the fuel pump. Seems like I have to drop the gas tank and to do that I probably have to drop the engine. I have the Haynes manual but surprisingly haven't found any tutorial online.
Can anyone assist?
Thanks in advance,
Josh
