@accolay avatar
@accolay avatar
Hello. Been lurking for a while since I rescued this rust bucket from Craigslist a few years ago. Just starting to have the time to get into it and noticing the VIN on the title is actually the engine number.
The VIN on the chassis is quite rusted. I think I have:
VBB2T ✬ 246862 ✬ IGM13800M
Any other ideas?
What is the last part with either IGM or 1GM?
@ricky_cantley avatar
Vespa 125GTR p125x p200
Have a look here at the scooter help web page link - http://www.scooterhelp.com/serial/ves.frame.serial.numbers.html
@accolay avatar
@accolay avatar
I've just been checking that site out. At least I know what IGM stands for now.
Any luck with what you can make out for the VIN?
parallelogramerist
parallelogramerist
If you don't mind getting rid of some of the rust to find out what the frame numbers are, use OSPHO metal cleaner and a wire brush. It will remove that rust with no problem.
http://www.jamestowndistributors.com/userportal/show_product.do?pid=557
79 P150X, 69 Sprint V, 80 50 Special, 85 PX150E
Seems you have it right. Search IGM 1380 om
@accolay avatar
@accolay avatar
The frame will be media blasted eventually, but i do have some naval jelly and another rust remover around. Is OSPHO more effective? I've never used it.
parallelogramerist
parallelogramerist
it's effective enough that you'll want to wear eye protection, rubber gloves, and a respirator...
@siggy_javotnik avatar
05 GT200, 77 Serveta Jet 200
You can also just use WD-40 and a soft wire brush.
The first two characters look like "V1" to me (the base of the "1" seems too broad to be a "B," but who knows what will turn up after you scrub rust away). Where do you live / did you find the bike? Context clues can help us.
I second using Ospho, good stuff. You can brush it on easily and it will turn the rust a dark blue/black. It is an acid, so use some eye protection.
lml vb1 vsb
lml vb1 vsb
After a little wire brushing you can either do a pencil rub onto a piece of paper to see the numbers better or my prefered method of smearing a little paint across the vin number.
@accolay avatar
@accolay avatar
It's a 1965 150 VBB2T (I'm assuming). I'm in Minnesota. I got it I think in 2014 off Craigslist. I wish I had known about the VIN then, but I now now the VIN on the title is the engine number (got it from Wisconsin)
What else could it be? It fits the serial number range for 1965 and the last two characters of the prefix is 2T. Right?
[ Time: 0.0150s ][ Queries: 4 (0.0082s) ][ live ][ 343 ][ ThingOne ]
