Hi all
I've taken out the steering tubes to replace the notched head bearings, but the first bearing I've had a look at is completely stuck on. I've tried to knock it free with a center punch which seems to be the common method but it woudn't budge. I've removed the bearing cage with an angle grinder because it was getting pretty bashed up after the hammering with the center punch.
I've also tried cutting into the race carefully with an angle grinder to see if I could free it, but still no joy and I don't want to cut any further in case I go into the steering tube itself.
My next thought is to let it sit in some penetrating fluid for a day or two and then try again with a new sharp cold chisel, if that doesn't work then weld on a plate to give some purchase and get a long pipe on it and try and use that to turn it and break the grip. Hopefully the penetrating fluid, some heat from the weld and some leverage might move it.
Anybody who wants to see what the inner race of a notched bearing looks like after a gonzo tweak, have a look below!
