I need some advice. My kit has arrived and in preparation for fitting the kit i have mounted the rings on the piston and installed one gudgeon clip on the timing chain side of the piston.
The bottom ring is the oil control ring and composed of three components a thin ring top and bottom of the slot and a waffle spring tension ring in the middle. My issue is that the ring is very tight in the slot and does not seem to squeeze down well to bore diameter. I refitted all the components making sure there was no overlap of the waffle ring.
The piston with all rings in place does go into the bore but is very tight. I can see that there is still a ring gap of about 1-2 mm as the bottom ring goes in but everything is very tight. So tight that it is quite an effort to move the piston within the bore. I did oil the bore and the piston and rings. Top two rings are fine.
Not sure if this is normal or if i should be worried?
