MP3 500
MP3 500
1. I am noticing while driving under about 40km my MP3 500 doesn't sound good or feel good very laggy and jerky. I am told it's time for a belt, rollers and variator. I am new to MP3ing so should I just replace stock?
2. I have noticed my brakes squealing a little but I am told they look fine should I be worried?
3. When parking should you always use the centre stand?
4. Is there a way to adjust the front suspension it feels very hard to me coming from a motorcycle?
THANKS!
It would be helpful if you stated the model year and the mileage on the scooter and if you know, what service has ever been done, either by you or a previous owner.
#1- Depends on miles.
#2- Depends on miles. You can also visually examine the brake pads to see how much has been worn down.
#3- Why do you ask that? What has someone told you? Generally, for up to one week parked, I used the front end lock. Longer than that, I used the center stand.
#4- Does it feel "hard" because you feel the bumps and potholes more than on your motorcycle? It's a common complaint of most scooters. It's mostly due to smaller wheels and less suspension travel. Again, knowing the mileage will help us determine if your shock(s) could be worn.
MP3 500
MP3 500
Sorry 2009 Piaggio MP3 500 16,500 km
I have just purchased the bike I just had an oil change, spark plugs replaced and all 3 tires replaced.
[ Time: 0.0088s ][ Queries: 3 (0.0019s) ][ live ][ 341 ][ ThingOne ]
