I have a 6 volt battery-operated super with a short. My headlight/taillight fuse kept shorting out intermittently and it didn't seem to be too big a hassle until yesterday, when it happened 3 times. It looks like the short is in the green wire to the left of the (top) fuse (see pic below), it seems to be shorting out on the metal tab that keeps the cowl attached to the frame. The metal tab is rubbing on the underside of the connector and has worn the plastic off the connector so it's metal to metal. I didn't figure this out until it was getting kind of dark last night so I loosened the nut on the tab, wedged a doubled up piece of electricians tape under it, and tightened it again while pushing the tab down a little, away from the connector. I tested it out and it's not shorting now, but it's not exactly a permanent fix, either. It seems like the little cowl tab will continue to wear on the connector there and, once I replace the connector, it will wear away the plastic on the next one, too.
Are any others with battery-operated supers having this issue? Any suggestions on how to correct this? Seems like a stupid place for the metal tab to be, right in between the wires to the fuses. Sorry my picture is so lousy, it was dark and I had already shoved the tape in under there, so you can't really see the plastic connector or the wire, so you have to use your imagination
