Piaggio fly 150
Piaggio fly 150
hey, I have a 2009 Piaggio fly 150 and recently done a gear oil change twice on it. At first the gear oil change I did, I filled up the gear oil to the middle and drove it for 30 something miles. I recently did some only searching and found it that there are different amount that people are saying. Some of the things I hear was to fill it to the dot, others I hear was to fill it to the first line, and the last thing I heard was to fill it to it to the second line. Please help I am very confused on where the max and min are for the gear oil on the stick. On the second gear oil change after the 30 mile ride I filled it to the point where it pasts the dot but not over the first line. Please advise on how much ml to put and where the gear oil should be when checking the dip stick
Piaggio fly 150
Piaggio fly 150
Mike888 wrote:
hey, I have a 2009 Piaggio fly 150 and recently done a gear oil change twice on it. At first the gear oil change I did, I filled up the gear oil to the middle and drove it for 30 something miles. I recently did some only searching and found it that there are different amount that people are saying. Some of the things I hear was to fill it to the dot, others I hear was to fill it to the first line, and the last thing I heard was to fill it to it to the second line. Please help I am very confused on where the max and min are for the gear oil on the stick. On the second gear oil change after the 30 mile ride I filled it to the point where it pasts the dot but not over the first line. Please advise on how much ml to put and where the gear oil should be when checking the dip stick. Thanks
@andythebuilder avatar
250 gts, nitroed zip 69cc " the teenager", 200 now 300 lc zip "all grown up"
Mike888 wrote:
Hi Mike
The stick is used across the piaggio range of scooters 150.ml is the correct amount of oilfor a fly 125
Cheers Andy
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
The workshop manual in the wiki section says 200ml of gear oil for the 150 fly
Piaggio fly 150
Piaggio fly 150
So the correct amount should be 200ml. Also what line would it fill it up to
Piaggio fly 150
Piaggio fly 150
Last question could I have damaged the transmission by overfilling it and running only 30 miles on it
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
I just drain then measure out the correct amount and refill , If you have the owners manual it shows the correct level on dipstick which on my fly 125 was the first line and about 1/2 " up
Piaggio fly 150
Piaggio fly 150
The problem I'm having is I drained it out but didn't measure the old one. Im not sure what was in there originally
@madison_sully avatar
I wouldn't worry about it.
Get it close, and go.
Piaggio fly 150
Piaggio fly 150
Wait so the amount is 200 and not 150 right
According to Super-Fly, the manual says 200mL.
Piaggio fly 150
Piaggio fly 150
Ok thanks. Would you know where I can get a 2009 Piaggio fly 150 owner manual. The owner I bought it from never gave it to me.
Piaggio fly 150
Piaggio fly 150
Also does the fly 150 and 125 take the same amount of gear oil
i stand corrected
Hi all
my workshop manual state's fly125 150 approximately 200cc
But all other piaggio 12 inch wheel 125 150 approximately 150cc which is very confusing as they all share the same gearbox.
A fly 100 has 80cc of gear oil
The above are for 4t motors only.
Cheers Andy.
Piaggio fly 150
Piaggio fly 150
Its gonna be hard since I don't know where exactly the gear oil has to be on the dip stick
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
Forget about the dipstick & just fill with 200ml of oil it's really that simple
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
There's a PDF version in the wiki section
Piaggio fly 150
Piaggio fly 150
But the problem is that there are piaggio scooter/ vespa scooters that have the same engine and transmission but those that are 150 are taking 150cc of gear oil. Also is the 07 fly 150 the same specs and engine as the 09. I read the 07 manual, but I saw that the place to drain the gear oil on a 07 is right under the dip stick while my 09 is on the right needing a size 6 hex same side on the rim.
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
Same leader engine in fly from 2005 > 2012 , Gear oil drain plug in same place behind wheel
Yes some piaggio / Vespa scooters take different quantities of gear oil , That's why they specify the amount in the owners manual
Piaggio fly 150
Piaggio fly 150
Ok so 200ml should be enough. Just wanna double check. Sorry I am very protective of my scooter since it is my only way of transportation from and to school. Also is it normal that you need to add a little throttle to start scooter from cold. Mine never started without adding little throttle. Also when ridding there is a small popping noise when decelerating.
Piaggio fly 150
Piaggio fly 150
Also what is the difference between a m571m and m573m engine. Currently mine is m573m
@thenaughtylemur avatar
2006 Suzuki S40 - 1978 Puch Pinto (sold) - 2006 Piaggio BV250 (R.I.P.)
Its carbed, so having to do a bit of throttle to get it started is normal. The small pops are also normal.
⬆️    About 5 years elapsed    ⬇️
2006 piaggio fly 150
I know this is a super old thread but I'm going through the same thing on my 06 piaggio fly 150. It's apparently super hard to find information on the first generation piaggio fly. This thread and a scanned document of a service manual are all I can find. I went to change my hub gear oil today and I see you guys saying 200mL is correct? The service manual I found simply stated it should be filled to the bottom most notch on the dip stick. But 200mL brings me to the 2nd notch from the bottom. To make matters worse I measured 340mL that I drained out of it we've been riding this scooter for a year like that. I guess the previous owners shop of choice didn't service it correctly? I just want to be double sure 200mL is correct, it seems like it should be 100-150mL as that would put it at the first notch like the service manual states and that's what the similar leader engine Vespa calls for, no? I still can't believe I drained 340mL out of mine like what even...
@cosmos avatar
2009 LX 150, 2024 GTS Super
@cosmos avatar
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
[ Time: 0.0094s ][ Queries: 3 (0.0027s) ][ live ][ 339 ][ ThingOne ]
