@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
Tomorrow i will recieve a test set of Hagon shocks with 14kg spring installed
This winter Hagon UK will try to develope shocks for the front for the mp3
@buckeye_marksman avatar
MP3 500
MP3 500
Re: Hagon shocks rear 40cm length
Thanks for the update. Do you know how much these will cost?
@klaborde avatar
@klaborde avatar
Can't wait to see them.
Keith,
Marietta, GA
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
well here they are
@klaborde avatar
@klaborde avatar
The shocks in your picture look like Rear Shocks.
I did not read you first post correctly.
I was anxious to see the ones for the Front I thought you were receiving.
I will post a recap of my solution for the Rear which has proven to work out very well.
Thanks,
Keith
Front of a MP3/250
Front of a MP3/250
⚠️ Last edited by klaborde on UTC; edited 1 time
@klaborde avatar
@klaborde avatar
Here is my solution for the Rear...
This will fit all of the MP3's in the US currently, unless the Gilera is different?
Drops the Bike about 2".
Picture shows Stock MP3 Shock, and the Hagon Shock in Chrome.
Also when you lower, the top 2 Screws on the MP3/500 Sport Air Filter need to be removed. It will be hard to get to them once you change the shocks.
Information for Purchase in the US.
The information on the Shock if you want to Contact Billy and order some.
Phone: 760.308.8124
Parts Info:
Road Shock 360S SS16234C SR Pair (360MM Length, Larger MM available)
10x24MM Bonded Bushing
8 x 3MM Spacers (Required to fit properly for 30MM width.)
The price is $219.00 plus the Spacers from Billy.
Stock Shock vs Hagon Shock Replacement in Chrome.
Side by Side view of a Stock MP3/500 and my MP3/500 lowered on the Right.
MP3 500
MP3 500
I really like the lowered look. How does it feel any different?
@new200guy avatar
2019 MP3 500hpe Sport
@new200guy avatar
Are your Hagan's running a harder rear spring? I feel as though the MP3 could use a little more damping in the rear, as through corners with small undulations in the road, the back end feels a little squirmy and not 100% confidence inspiring...sometimes. Not like this is a serious problem, as the German's keep their roads well maintained unlike in the states. I know this is not a sport bikeby any means, but it does a pretty good job attacking corners. Although the center-stand gets in the way on hard left handers. Right handers got better with the new LV GT and no muffler guard to drag.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
the stock springs ar 7kilo hagon comes with 14kg
@klaborde avatar
@klaborde avatar
I can't tell accept I can put my feet down and have a better warm-n-fuzzy when I stop. I have the Piaggio Gel Seat which help a little.
Keith
Marietta, GA
2008 fuoco
2008 fuoco
Maksor wrote:
well here they are
Interested to know how have you found them.
3legsofman wrote:
Maksor wrote:
well here they are
he sells them
2008 fuoco
2008 fuoco
old as dirt wrote:
3legsofman wrote:
Maksor wrote:
well here they are
he sells them
Yes i know , but as they are a TEST PAIR and hagons can alter the internal damping setup ,i'm interested to see how he found them performance wise over the ones he currently sells, before i ask hagons about them as i live in the uk.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
Well they are 1cm to short and wont fit will hit the mounting
waiting on other ones
2008 fuoco
2008 fuoco
2008 fuoco
2008 fuoco
I do have to wonder about hagons sometimes. I was at the classic show at stafford UK in Oct and asked about the availability of shocks for the fuoco .There still working on them was the answer!
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
they still are also for the front
@clawhn avatar
MP3 500 abs (blue)
@clawhn avatar
MP3 500 abs (blue)
Maksor, do you know if the Hagon trial shocks are designed to lower the ride height like the ones sourced in the US by Klaborde?
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
no 40cm ar same as stock if you want to lower i can supply 38, 36 or 34 cm shocks
[ Time: 0.0145s ][ Queries: 4 (0.0066s) ][ live ][ 343 ][ ThingOne ]
