Hello guys!
I found tons of interesting info about my mp3 on this forum, but mine is still resting (wont start).
I removed all the plastics and start with the troubleshooting checks as writen in service manuals. So far I had no luck at all.
I noticed that the coolant reservoir / tank is completely empty / dry.
Is it possible that scooter has some sensor which prevents the motor to be started when the system is low on cooling liquid?
1) I HAVE CHECKED THE BATTERY / REPLACE IT WITH NEW ONE
2) STARTER MOTOR WAS DISASSEMBLED AND CHECKED
3) STARTER RELAY WAS REPLACED WITH NEW ONE
4)IMMOBILIZER CHECKED
5)STARTER BUTTON AND BRAKE SWITCHES CHECKED
Sometimes motor gets spark, sometimes not, depends how many times i turn the key and start the starting sequence.
The starter is still not spinning / turning using starter button, just using relay / directly by hand
https://youtu.be/TAFNJzzYKWk
Thank you for helping me out.
Cheers, KIKI.[/url]
