mp3 250
mp3 250
My starter relay died. So I replaced it. 2007 Piaggio MP3 250. just had front end rebuilt at dealer last winter
Now when I power up, it give me a screeching rapid -beep error.
Will not turn over either
wheels remain locked
I am in Victoria BC canada
Any ideas??
@klaborde avatar
@klaborde avatar
Re: Rapid beeps error, no start??
Any ideas??
I haven't had that one yet...
I am sure this is obvious, you checked battery?
Keith,
Marietta, GA
mp3 250
mp3 250
battery is new, it was fully charged 2 weeks ago. but the bike sat unused since
I just put the charger on it on your suggestion ... and it says low, I think. So thanks for heads up. Will check back in a while after charged
@klaborde avatar
@klaborde avatar
battery is new, fully charged
maybe it is oil. like the kind of alarm I find on a boat with low oil. oil pressure or overtemp
Normally, when you turn the key...
You here the sound of the Fuel pump, is that working.
I do remember now getting that sort of beep when I had an intermittent connection to the Dash Panel once.
There is a post on youtube on MP3 Beeps, let me see if I can find it.
If I do, I will come back and update here.
Keith
@klaborde avatar
@klaborde avatar
This fellow posted a similar video to you...
I would message him by commenting on Youtube.
https://www.youtube.com/watch?v=KovzFM_rs7k
Still searching for the other one.
Here it is...
See if this helps.
https://www.youtube.com/watch?v=vGSdFmgTTJs
Keith
mp3 250
mp3 250
hmm in those videos the symptoms are completely different
I think I will disassemble the front and check the steering hydro fluid level
otherwise .. I gotta flatbed it to a dealer! grrr
@apsevtorontowest avatar
Vespa Dealer
Vespa Dealer
Low hydraulic fluid = Horn will honk 5 consecutive times
Electrical issue = solid beep tone from parking ECU
2008 fuoco
2008 fuoco
Was the bike ok BEFORE you fitted the new starter relay?
If so i was going to say that there are some starter relays ,certainly on the gilera fuoco and i assume the mp3 500 that i've seen on ebay and i have bought one that look the same except that the fuse is in a different position. THESE ARE WIRED DIFFERENTLY.
⚠️ Last edited by 3legsofman on UTC; edited 1 time
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
You have blown the parking ECU i think you missplaced the + and - on the battery or starter relay
@klaborde avatar
@klaborde avatar
[quote="Maksor"]You have blown the parking ECU i think you missplaced the + and - on the battery or starter relay[/quote
Ouch !
That's not Cheap...
Retail US Dollars is around $475.00
A few on ebay.
Be sure to verify your part number, I believe these will work.
Get ready to take all the Body Parts off the bike to get to it.
It is sandwiched near the Parking Brake ABS and the Fender Well ABS.
http://www.ebay.com/itm/Piaggio-MP3-250-IE-Steering-Anti-Roll-ECU-2009-/122031684125?
http://www.ebay.com/itm/09-12-PIAGGIO-MP3-250-STEERING-ANTI-ROLL-ECU-PIECE-/301994739104?
I always keep a few spares myself for just in case.
Keith,
Marietta, GA
mp3 250
mp3 250
yes bike was fine before
ah. my worst fear. ha
OK I ordered the OMRON relay from an online Vespa supply store. The markings look identical at the pins, but then I am not familiar with what the markings mean. That must be the nub of my problem!
Ordered a new ECU and I think I will order a new relay from the dealer in town, just be sure it is the correct item.
I did make one mistake in re-assembly: I did not reverse the polarity at the battery, but I did leave off one of the positive leads to the battery which I discovered and then attached later.
I am now well practiced in removing most of the plastic now - ugh
thanks for the help guys!
[ Time: 0.0114s ][ Queries: 3 (0.0018s) ][ live ][ 343 ][ ThingOne ]
