My old exhaust wasn't worth trying to preserve any longer, I couldn't afford a new Piaggio exhaust and I saw a cheap 2nd hand steel exhaust (an LV Grandturismo) for sale. It fitted easily enough but I completely lose ooomph at 3/4 throttle and above. It's fine to start and at all throttle settings up to this point. My guess was I needed to change the main jet.
I just took off the carb - not as difficult as I was fearing but I have some questions.
A) this looks like it needs a tube attached but it doesn't have one - is it just for draining the carb?
B) this is just an open tube - what is it?
C) I assume it's a walbro carb with the metal cap on top with 2 screws?
I bought some minuki jets but the ones I've bought are way too big. I took out the existing main jet and it appeared to have a small hair in the jet. I've cleaned it but not put it back together yet. Would cleaning it out fix my problem at 3/4+ throttle? if not what jet should I get? and would swapping the jet to a larger one fix my issue?
I cleaned around the float bowls etc with a paper towel - it wasn't too bad considering it's not been touched since I bought it in 2003? Anything else I should do while it's out?
These days I only ever ride the bike 5-10 miles at a time. Am I likely to damage stuff if it's running too lean? how do I tell when I've got it right? - I was just going to buy a few random jets and see what worked.
Mike
PS Just in case it sounds like I know what I'm doing I'll warn you I don't.
