As a once regular here I say hello again, and thinkI will be around
a bit more.
Yesterday sold my Mana, and am back to just MP3 500 and Vespa GTS 250.
Have gone through as many related postings this morning as I can stand but have not found the answer I sm looking for.
Bad Rob, but through sheer laziness I let the fluid in the tilt lock
run low because checking it meant taking the 500s plastic off.
So, as it should, it blared my really loud aftermarket horn.
After refilling it continues to blare.
I went back in to see if the fluid had leaked out but fluid still there.
My guess is by getting low ( empty really) I may have screwedup the sensor. Maybe need to have it replaced.
On my other 500 we had a similar scenario and finally just gave up and disconnected the sensor, so I am a little reluctant to go down that path again of replacing things to no avail.
If anyone has had this same issue and found any fixes, from having let the fluid get low, would love to hear it.
Bike is fine if you do not engage the wheel lock but I miss the locking wheels part of having an Mp3.
