@brown_beret7 avatar
1975 Vespa GTR 125, 1976 Vespa V90 (Resto), 2001 Vespa ET4 125 (Sold), 2009 Vespa GTS300 Super
Todays press release from Piaggio about the new European Sprint and Primmy with iGet engines and new accessories...
http://www.piaggiogroup.com/en/archive/press/new-vespa-primavera-and-vespa-sprint
You heard it here
Air cooled and drum rear brake still.
Thought this might have stoked up more interest, given new models n'all. I guess not
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
Not very clear what's "new".
@primablanco1 avatar
2015 Primavera 50
2015 Primavera 50
I want my PX.
Anyway, the idea of a barometric sensor for the ECU scares me. Did I read that right? Is this sensor a first or an upgrade? What will happen when atmospheric pressure fluctuates wildly as it sometimes can? I've had cars that experience performance problems due to 02 sensors and the climate I'm in (this according to the mechanic.)
GTS300
GTS300
Re: Piaggio press release - New euro Sprint and Primavera mo
You heard it here
I am assuming the new GTS will have a version of the iGet engine, what do you think?
@theknights20 avatar
Vespa s 125 ie 4t
Vespa s 125 ie 4t
You heard it here
More than likely for the gts125 as it does state it's available in a 4 valved lc version. The 'larger models' will probably have a different engine altogether and hopefully will have a true 300cc displacement... Or higher, wouldn't mind!
GTS300
GTS300
theknights20 wrote:
You heard it here
In Scooter Lab's test of the Medley 125 they mentioned that the iGet would be available in larger capacities, I just wondered if it would end up as a 250 or 300, maybe not!
http://www.scooterlab.uk/piaggio-medley-125-road-test/
GTSRad made a good point, the new engines have the radiator on the outside, if this design feature is on a new 300 engine would the GTS still need to be double skinned?
Good post AWB We do like a bit of speculation. I think the iGET engines and the Medley setup could well be the forerunners of the next GTS spec.
theknights20 wrote:
You heard it here
All the hints I've seen are that the performance and emissions will improve for Euro4/5 and you'll get a slight pep in scoot performance overall, but you WON'T see a 300cc+ engine in the GTS replacement...
Check out the no longer revolutionary lower front shock mount.
Vespa s 125 ie 4t
Vespa s 125 ie 4t
brown_beret7 wrote:
theknights20 wrote:
You heard it here
Surely that depends in how piaggio are getting around the emissions. If we do get a bigger i-get engine then it would be quite funny if its exact same displacement as the old model. Who knows, the Italians may like funky numbers. Anyone know if they're reusing the bores? Would probably answer the question.
-face palm- half asleep, just woke up! Thinking about it, the i-get sounds like an evolution of the 3v engine. Meaning that the quasar bore will probably not fit. But, you cab always hope for a bigger engine no matter how un likely it is
@melbelle avatar
PX150
@melbelle avatar
PX150
Just get a BV350 😋
Then your need for speed will be resolved!
@blackmoon181 avatar
LX125 (in bits) , Honda sh300i & NC750x
MelBelle wrote:
Just get a BV350 😋
Thats what i did. You can be a right hooligan on the BV which i don' t think is a good thing. Do you not miss the nibleness of the LX? i still enjoy wringing my other halfs LX's neck in the city.
Question for the engineers amongst us. Would the surface area of the radiator for the iGET engines be sufficient for larger displacements? Does anyone else know if this type of radiator design on other engines?
theknights20 wrote:
brown_beret7 wrote:
theknights20 wrote:
You heard it here
MVer Stormrider gave a very smart insiders view of engine design over in this thread. Smart guy and sounds very plausible that the new GTS design will go with his predictions... 2017 GTS 300 or 350cc ?.
@crazycarl avatar
@crazycarl avatar
Why did they make this change? I thought it was supposed to improve ride and handling.
@melbelle avatar
PX150
@melbelle avatar
PX150
Blackmoon181 wrote:
MelBelle wrote:
Just get a BV350 😋
If I move then I'd get a small frame scooter as well 😎 I've got used to the BV350 in traffic though, just have to remember it's s bit longer than the LX!
@mickfitz76 avatar
Yamaha XMAX 300, Sprint 150, PX 177 Polini.
@mickfitz76 avatar
I just had a test on the new Sprint iget engine.
The engine is nice and smooth and less vibration and has a nice mid range. They added abs finally for the Sprint in Asian market and the electric seat release and usb port.
But one thing they did was revert back to the old front shock and not the ess system on the original Sprint and face lifted GTS.
Didn't feel as sharp in the turns compared to my ess equipped Sprint so it's not worthy of an upgrade in my opinion.
Does come in a beautiful Matt red colour though.
⚠️ Last edited by mickfitz76 on UTC; edited 3 times
@mickfitz76 avatar
@mickfitz76 avatar
I didn't see this post before I posted above but yes. It's a deal breaker. Find a 2015 Sprint because it handles so much better and feels sure footed.
@mickfitz76 avatar
@mickfitz76 avatar
I was told the cost. Much cheaper apparently.
Where are you Mick? I'm hoping the cheaper suspension is asian market only.
@mickfitz76 avatar
@mickfitz76 avatar
I'm based in Thailand. It seems the whole world is getting the same spec I'm told. Really disappointing that they would revert back to this set up. It doesn't feel as planted when leaning. Like understeer if that makes sense.
@clodis avatar
GTS 250 ie RED DRAGON & new primavera red
@clodis avatar
My new vespa
@scootkiwi avatar
@scootkiwi avatar
Seems a step backwards alright and possibly a deal breaker for me on a new bike....
[ Time: 0.0280s ][ Queries: 5 (0.0113s) ][ live ][ 343 ][ ThingOne ]
