@duck204 avatar
Vespa Sprint 1970
@duck204 avatar
Vespa Sprint 1970
I have vespa sprint 1970 and i have problem with rotary valve. My fuel blow up from carb that condition become from side effect of my rotary design ?
Note : in few years ago i has been rebuild the rotari
Lambretta GP200, Vespa P200e, Motovespa do Brasil PX200E
What you said made little sense.
@duck204 avatar
Vespa Sprint 1970
@duck204 avatar
Vespa Sprint 1970
So, what should i do ? I must porting that rotary for smooting the surface
Note : i have not done for checking the gap betwen crankshaft and rotary but if the gap betwen rotary and crankshaft has normaly i should porting the rotary or you have any suggest ?
Rally 180, li150, P125, p200, p200, p200
I think he is concerned about the fact that he is experiencing some charge reversion through the carb when kicking the bike over.
Just a guess...
@chandlerman avatar
Innovator
241 Days Since Last Explosion
Innovator
@chandlerman avatar
If that's the crank visible in the first picture, then its surface is shot and needs to be replaced .
Rotary pad is probably trashed, too.
Does it hold oil if you try a leak down test of the crank and pad?
I fixed my rotary pad with JB Weld when I rebuilt it, but my crank surface was good and it passed a leak down test.
Good luck!
@duck204 avatar
Vespa Sprint 1970
@duck204 avatar
Vespa Sprint 1970
Good luck!
Thanks for your tips
But i have one question
I have been try a leak down test at crank pad. How long the liquid stay at crank pad if that crank pad is normal ?
[ Time: 0.0092s ][ Queries: 4 (0.0033s) ][ live ][ 343 ][ ThingOne ]
