hi
been trying to get the AGIP grease PV2
my piaggio dealer dont have it and my local dealer for eni/agip saying its out of Production.
what can i use instead ?
hi
been trying to get the AGIP grease PV2 my piaggio dealer dont have it and my local dealer for eni/agip saying its out of Production. what can i use instead ? |
GTS 300ABS, Buddy Kick 125
Posts: 13554 Location: Oregon City, OR |
Is this for lubing the steering bearings?
This question has been asked before. I was told by folks on this forum that AGIP grease is recommended because Piaggio has a relationship with AGIP but most people just use their favorite grease, whatever that is. Dooglas's suggestion is good. Just ask your dealer what they use. Or I hear many people here use a marine grease. I use Lucas Oil 10301 X-Tra Heavy Duty Grease- 14.5 oz ordered from Amazon. It's a water proof grease that's also all temperature stable. I think you should avoid grease that's too runny when it gets hot in the summer. Don't want it to drip out of the steering bearing opening all over on your wheel guard. |
Posts: 45826 Location: Pleasant Hill, CA |
Geir wrote: Dooglas wrote: Why don't you just ask your Piaggio dealer what they use instead? |
grease equivalents
hi,
i've found that dealing with fluids comes down to matching EU standards and if you have the patience to compare spec sheet details. i contacted motorex about the following greases for the mp3 250 (2007) they were quick to reply. rare customer service. high points for motorex. [...] Thank you for your trust in our products and your choice. The surched grease for the tone wheel revolving ring is the MOTOREX GREASE 218 M (AGIP GREASE SM 2) The grease MOTOREX GREASE 194 corresponds to the classifications of Agip GR MU ep 3 and is to be applied to the odometer transmission gear case. Have a good trip. [..] so i try to match the european DIN and ISO standards as well as the north american designations like "NLGI level 2". pay attention to the chemistry and additives like lithium, molybdenum. the temperature range is important to note when you review the spec sheets. so by example ... i matched the AGIP SM2 to a shell product because i have trouble finding the motorex product. i would have purchased motorex but sourcing it is similar to sourcing AGIP. difficult. AGIP SM2 is equivalent to motorex grease 218M. motorex made the AGIP product match. the motorex (and AGIP grease) has a DIN of DIN KPF2K-20 so if you search shell grease and the DIN KPF2K-20 you get a match i went over the chemistry, added components and use cases and there's a match there. temp range was good too. that DIN matches the motorex grease motorex supplied me. the shell product for AGIP SM2 is Gadus S2 V220AD 2 found by searching for shell grease and the DIN Shell Gadus S2 V220AD 2 Vorherige Namen: Shell Alvania HDX, Shell Retinax HDX Hochleistungs-Mehrzweckfett mit MoS2 (KPF2K-20) so finally i can say AGIP SM2 by way of motorex 218M (sorry motorex had trouble buying that particular motorex grease). is shell Shell Gadus S2 V220AD 2 as a safe replacement if you go through a similar process you can find an equivalent grease that is as available in north american as it is in the USA. once you find a product that is as available in the US and Canada as it is in the EU it's easier to find more than one competing product. Eg shell, castrol, mobil, esso etc. pdf
522kb
⚠️ Last edited by greatlake on UTC; edited 1 time
motorex contact and spec sheets for mp3 2007 greases
followup to my previous post.
attached motorex spec sheets for two greases used mp3 2007 for agip SM and the one for the speedometer .AGIP GR MU. in previous post. AGIP SM = motorex 218M contact info from motorex for canada. can try to source local re-seller if desired.Here attached please find the requested Technical information sheets. Here you can find the address of our Canadian distributor. Parts Canada/Power Twins 2916-21 Street N.E. T2E-6Z2 Calgary, Alberta Phone 001 403 250 66 11 Fax 001 403 250 79 84 E-Mail: information@partscanada.com With best regards pdf
522kb
Posts: 4309 Location: Marietta, GA |
Re: RED LINE CV-2 Grease
MOTO3 wrote: REDLINE CV-2 Synthetic Moly Grease is also a good choice. This is what I have been using for about 3 years. Keith, Marietta, GA |
klaborde wrote: MOTO3 wrote: REDLINE CV-2 Synthetic Moly Grease is also a good choice. This is what I have been using for about 3 years. Keith, Marietta, GA from what i've learned well chosen solids can buffer or cushion "bump" stressors. molybdenum also has other features like enhancing lubrication properties. |
grease cross reference many north american greases listed
hi,
i found this automotive grease cross reference that mentions AGIP, shell, castrol etc. should be useful. once you find one grease easy to find in north america it's much easier to cross reference to match others. this table is pretty good. |
