So, bought a new Yuasha battery about 10 months ago and all seemed good until the other night when my wife couldn't start it.
The bike has no alarm to drain battery, the bike had a new rectifier last year and checking the volts when running is charging fine even with lights and high beam on.
Some journeys are just a couple of miles but rest are about 9 miles long.
Today she left for work with freshly charged battery, rode the 9 miles, parked there for about 6.5hrs, rode the 9 miles back and I checked the battery upon her return and it was only at 11.94
Assuming the rectifier doesn't have an intermittent fault and is as when tested, charging fine. What could be draining the battery when parked?
My thoughts are can't be a relay as everything works as it should and only when it should.
I'm sure it was a coincidence but this only happened since a car backed into her bike last week. But no, bike was not left sat on side and battery levels are correct.
I thought about changing to a lithium battery but the battery should not have failed after just 10 months.
Will go to the bike shop on Monday to see if they can load test it but assuming it's fine, any ideas?
