lml nv 2010, vbc ,small frame
hi guys what gasket sealant do use on the case gaskets, cylinder gaskets and carb gaskets looks like i can only see sealant the reed gasket not sure what to use or not to use any sealant? thanks
@chandlerman avatar
Innovator
247 Days Since Last Explosion
Innovator
@chandlerman avatar
I use Permatex 85420.
Lots of folks use heavy grease.
This topic has been discussed repeatedly over the years if you just do a little searching.
(fixed Permatex #)
⚠️ Last edited by chandlerman on UTC; edited 1 time
@drona avatar
59 Vespa, 65 Vespa, 66 Vespa, 57 Vespa
@drona avatar
Grease only for me...
@october avatar
64 allstate, 66 sprint, 74 primavera, 79 P125x
@october avatar
Grease
Whatever I have lying around.... Seriously, just thick grease put on as thin as I can squeeze between my fingertips with the gasket in the middle. Just saturating the gasket with enough to hold it in place.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Grease if the surfaces are in good shape, Motoseal if in doubt.
Case gaskets: Hylomar
Cylinder and exhaust: Mega Copper
Carb: Grease
[ Time: 0.0090s ][ Queries: 3 (0.0020s) ][ live ][ 343 ][ ThingOne ]
