So I had an exciting few moments on my scoot Saturday evening...
Coming around a corner and I hear several pings followed by some sicking cthunks while feeling the rear end start to wobble...
It turns out 4 out of 5 bolts sheared off -- I know I've never over-torqued these bolts, so the only thing I can figure is I've smacked a few too many speed bumps are too high of speed, and they finally gave up the ghost.
Quick call to a friend, and I've picked up some bolts from the hardware store, followed by some vocal musing about how badly named 'easy-out' tools are, and I've cleared 2 of the sheared bolts, enough to basically walk the bike the last 1/2 mile home.
I have a few questions for you guys:
The bolts seemed to be pretty soft compared to some VW bug lug bolts I had to drill and extract quite a few years back -- would replacing the bolts with hardened ones be a good or bad idea?
assuming I should just use oem bolts -- any idea who would have them?(i'd call AF1, but they are closed on Mondays.
I pulled and inspected (cheap microscope) the bolts for the front tires but
I'm not confident in my ability to spot metal fatigue-- think I should just replace all the front tire bolts as a precaution?
