I know this is Honda but wanted to share the info on what's inside this muffler !!!
Have seen Vespa muffler and info is good !
Ever wonder what's inside the HELIX muffler ? What's rattling ?
This is my 1986 OEM muffler that started rattling. I googled everything but never could find a definitive answer on what was inside.....answers from ceramic to catalytic converter to broken chambers etc. never pictures !
A few years ago I cut a small across and found the rattle and removed it and welded it back up but removing a broken pipe just messes up exhaust flow ....
Anyway I decided to fully understand the muffler so here it is exposed once and for all !!
I painted it for easier understanding.
First of all the rattle is a longish pipe that breaks clean off from the entrance manifold to the pipe in the first bulkhead and just annoyingly rattles!!
I made a plastic pipe to simulate the proper connection !
The muffler is double walled with fiberglass between. The inner is perforated mesh.
There are 2 sealed all around baffles that all piping is welded to, effectively making 3 sealed chambers ...
Exhaust starts down through Orange pipe passing through (NO OPENINGS) the Bulkheads and dumping out in chamber 3.
Then it goes through the slightly hidden White tube and dumps out in chamber 1.
Now it goes through the Peach pipe and dumps in chamber 2.
Finally it enters the Lime green pipe to hook around and exit the muffler.The large bulbous end on the orange pipe looks like a resonator of sorts. has a perforated inside pipe and the exhaust just goes down the center and exits in chamber 3.
nothing in the walls.. just a pre expansion area ?
The bulbous end on the Lime green before the exit has a plug at the beginning and a perforated interior pipe.
The exhaust hits the plug and goes around the perforated interior pipe and goes through all the holes and down the middle out the end exit.
It is quite the muffler. never took one apart before. Quite a long length inside with extra expansion chambers also.
