Piaggio 500
Piaggio 500
My boss recently went out and bought one of these Piaggio scooters.
I'm a car mechanic but I figured i'd give getting this thing running again a shot.
He bought the bike in NJ and rode it home to Pittsburgh PA
After he got home, the bike would no longer run.
I'm not 100% sure on the year but I can say it is FUEL INJECTED not carb'd. Says 500IE or EI on the body.
With that being said, after checking for spark/air/fuel, it seems there is no gas getting to the injector. So, like I have found to be the problem with many cars I swapped out the fuel pump today (pump unit only) and there is still nothing at the injector no matter how long i crank it or anything.
Bike had 320 miles on it before the purchase, and he's really not trying to drive back to NJ with it to have it looked at when he just got it home.
Spark Plugs were also just replaced for shits and gigs because he didn't want me to just tear it apart at first.
From my tests all the fuses and relays seem to be in proper working order. but im not sure if i may have missed one or am looking at the wrong thing.
Any help is appreciated!
Piaggio 500
Piaggio 500
Not sure if these scooters have like an ECM type deal that could possibly be faulty? I see they have a check engine light but Im sure they require a special tool to scan and not just anything I have around...
check ALL the fuses.
Piaggio 500
Piaggio 500
Going over them again now, not sure if I might have missed some that are hidden somewhere.... Also just popped off the fuel line (tank to injector) to check if the pump was even pulling fuel and the line had a decent bit in it. Blew through it to see if there was an obstruction and the gas came shooting out the injector side. Could it be I just am lacking patience and need to let it crank a little longer?
portofino green GTV 300
Is the kill switch on.
When you first switch on, before trying to start, can you hear the fuel pump whirr for a couple of seconds? If so, then the 'injector loads relay' and the pump are OK. If not, then the most likely thing is the fuse that feeds the relay, followed by the relay, and most unlikely is the pump.
Next - check for spark, etc etc...
Note on some older Piaggio X9 500's, the kill-switch allowed it to crank but the fuel and spark were stopped.
Piaggio 500
Piaggio 500
Kill switch is set to RUN, Kickstand is up, seat switch pressed.
Hard to hear if pump is running in the warehouse with all the other noises going on. Not sure if the compression from the piston is what drew fuel into the line after pump replacement or if the pump is functioning...
Doesn't help any that the manual im going off of's font is like like 4 or 6 point so it's damn near impossible to read for me... Not exactly sure which Fuse / Relay / etc is in direct correlation to the fuel system. All of them are testing out O.K.
Piaggio 500
Piaggio 500
Where would the injector load relay be located?
The one hanging off the side of the frame?
At any rate what should these test to?
First off, what '500' is this? An X9, a Beverly or an MP3? When we know that I can point you at decent wiring and workshop manuals.
@davelx avatar
2016 Piaggio BV-350
@davelx avatar
2016 Piaggio BV-350
Post a pic of the scoot and we at least know what we're dealing with here!
@lomunchi avatar
2020 Honda NC750DCT
@lomunchi avatar
2020 Honda NC750DCT
I think the Scarabeo is labeled "500ie"
Buddy 125, Scarabeo 150, Scarabeo 500ie, Triumphs, Vespa Sprint 150
Location: Charleston,SC-Knoxville, TN- Sanibel, Florida
Yes, Aprilia Scarabeo 500ie.....or maybe a Piaggio BV500.
Not sure which yet.
Maybe neither.
fried okra
[ Time: 0.0123s ][ Queries: 3 (0.0052s) ][ live ][ 343 ][ ThingOne ]
