Just bought this Vespa 100 Sport small frame.
The front brake is total crap. When I got it it was all out of adjustment, and the lever would pull all the way without any braking action. I adjusted the brake at the adjuster on the front wheel until the lever would actuate after a normal amount of play. It seems to be adjusted well and the wheel turns smoothly.
Problem is, the braking action is still very bad. You have to pull VERY hard before you get any braking, and then when you do, it comes on really hard. When you're moving fast, and you pull the lever hard, you feel tension at the handle-lever but no braking action until you squeeze it VERY VERY hard.
What's up with this? How do you take the front wheel off to have a look?
Thank you,
