Picked up the scoot today after having an exhaust installed and noticed the rear wheel is not spinning during idle. It drives fine, clutch engages and it takes off well. I just noticed ,however this could have been happening since I installed the Malossi Delta clutch last time I was in the transmission case. Is there any concern I should have with this? The brake is not engaged at all also. Could this be due to a really loose belt?
When I give it an assisted push it will spin for a minute, and then it'll act like it just can't quite get over that apex, and it will just stop.
Thanks -Cole
