Well, I got the Bitubo front shock on the LX150 today. Another of those jobs that looked like it would take an hour, maybe more, that ended up taking three... Taking the old one off I could not get the nut off the tophat that is located on the brake/speedo side off. Grrrr. Then when I put the Bitubo on I had a bear of a time getting the same one started. I ended up getting the bolt shoved up into the hole and couldn't get it out. I ended up reaching around the top with one of those pick tools to get it loose.
Other than that, it was pretty straightforward to swap the new for the stock shock.
So, the instructions are next to worthless. How do I adjust this thing? The lower spring stop is adjustable, adding or removing compression, and the valving is adjustable. How much of each and when do I adjust valving and when do I adjust compression of the spring?
Also, did anyone get a spanner with their Bitubo? I didn't, and the spanner in the tool kit for the rear shock it too thick. I can grind it down to fit, but I don't want to too much for fear it won't work on the rear.
Thanks for any help,
Steve
