At 9,000 miles my first original piston cracked. I had a warranty that deflected all of the cost except $200. They replaced it with a new piston/ring/cylinder kit. I had my water pump go since then (another $700). I noticed some oil problems starting up after that point so I has them adjust the valves hoping that would help. Then I tried the ponydrv mod to see if it would push the oil back a tad. I now have 27,500 miles on the scoot.
Nope... all in vane. I was told I have a 30% blow-by and need a new piston/ring/cylinder kit. THIS IS NOW PISTON #3
I got a quote of $1,667 to do that work, flush out the rear brake and adjust the parking cable.
I asked to have a rep from Piaggio intervene. (Will that do any good?)
I hope this BS does not happen to anyone else!
