Greetings from Transylvania!
You can skip the intro and go to problems part
A little intro about myself: back in 1999 my father bought a moped, it was a Tomos Targa and that's how 2 wheels madness started for me. I drove that Tomos until the sprockets broke, the my father bought another moped, a Ramzey Wolf. The end for this one was when the cylinder broke. I didn't have any mechanic knowledge back then and the spare parts were very hard to find.
It was 2006 when I first drove a Vespa. I think it was a PK; it had manual gearbox and 80cc cylinder.
In 2008 I got my driver's licence and I bought a Kymco Grand Dink 250. I kept that scooter for 5 years and I've put more than 60000 km on it. I also learned some basic mechanics. Finally, in 2013 the cylinder broke after just 5000 km after replacing it and that was the moment when I realized I have to move on. The 250cc engine was quite small for my needs and I was fixing it more often than I was riding it, so it was time to move on. In 2014 I bought a 600cc Honda Silverwing and I put around 20000 km on it since then.
Lately I found that the Honda is too big and heavy for daily commute and after I rode a 150cc ET4 I felt in love
This year in February my girlfriend started to think seriously to get a motorcycle, but I thought it would be best to accommodate with the traffic on a scooter, so we bought a 97 ET2. I didn't do too much research when I bought it and I didn't realize the fuel consumption until after I bought it. The fuel consumption is around 4 liters for 100 km and that's a lot for a scooter that can't go faster than 60 km/h. This is the end of the intro is this is where problems start.
I searched for a way to swap the ET2 engine with an ET4 engine and after reading many topics on this forum I found out that I needed the whole wiring loom, with contact, CDI and so on. On this research I found out that there are 2 engine types (the LEADER and the Non-LEADER) and I lived on the wrong impression that only the LEADER has an immobilizer.
I found a good deal for an used ET4 125; the seller stated that he didn't have the ignition and the engine can't run, but that didn't bother me at all. I just searched the VIN in stolen motorcycle databases, it wasn't reported as stolen so I bought it.
Problems
After I bought the ET4 I found out that even non-leaders have immobilizers and I knew it was bad news. The previous owner also tried various work-arounds and made a mess in the wiring loom.
I almost sorted the wiring loom and I will try my luck to bypass the immobilizer with an Aprilia Scarabeo 150 CDI. For now I would like to know if the NON LEADER HT coil gets 12V on the purple wire just as long as the start motor or the engine is running. The main idea is that I don't have a spark. I removed the immobilizer and the original CDI.
Can someone please have a look at the workaround I tried and tell me what did I do wrong? Here's the ET4 wiring and in the attached PDF there is the Scarabeo wiring diagram. I considered the left wire from Aprilia CDI (42 in the diagram) as 1, the 2nd one as 2 and so on and here are the connections I made:
On Aprilia----------On Vespa
1--------------------W
2--------------------V
3--------------------1
4--------------------R
5--------------------B
6--------------------G
The other 2 wires from the original CDI were removed (the one connecting the CDI to the diagnostic port and the one connecting to the immobilizer.
My problem now is that I don't have a spark and the HT coil gets 12V on the purple wire only as long as the engine starter is spinning. I have 2 questions about this:
1. Is it normal that the HT Coil gets 12V only as long as the starter is spinning? Is it gonna continue to get 12V as long as the engine is running?
2. How do I measure if the HT Coil is working properly?
Thanks for reading this long post and I hope someone can clear things for me.
George
⚠️ Last edited by anothergxg on UTC; edited 2 times
