1980 P125X, 1978 P200 in pieces, 93 150 Exclusive (RIP)
Posts: 136 Location: New Mexico |
I'm trying to decoke the head for my P200. I'm using carb cleaner and a plastic (wire) brush. It is SLOW going, and seems that the coke in the center part (by the spark plug) might never come off. How long can I soak it in carb cleaner, I don't want to pit it or anything? Will that finally work? Is there a more aggressive abrasive I can use?
I think your method should work just fine...eventually. I've stopped using wire brushes as I fear a bristle sneaking down into a ring. No, it's never happened to me or anyone else I'm aware of, but why tempt fate. I personally use a screwdriver and gently scrape the carbon off. It usually flies off.
I had read that wire brushes can scratch the aluminum of the head and possibly ruin the seal it makes with the barrel, that's why I'm using the plastic one. Would a brass brush work? Do scratches matter if they are not on the part where it seals against the barrel, if they are just in the depression where the spark plug is?
Posts: 5108 Location: Australa, Mate |
Posts: 5109 Location: west aus |
Doesn't matter if you scratch a bit inside the combustion area you can wet sand too for a nice smooth surface
2005 PX150 In a Part-time Relationship with a 2-Stroke Vespa Since 2007
Posts: 1876 |
I read on a 2T moto-x forum once that this stuff worked great softening up carbon buildup for cleaning, so I tried it and lo and behold! It does!
https://www.permatex.com/products/gasketing/gasket-removers/permatex-gasket-remover-low-voc-formula/ |
Spray on oven cleaner....
And while your at it, buy an extra can to clean your BBQ grill. Chuck |
chuckactor wrote: Spray on oven cleaner.... And while your at it, buy an extra can to clean your BBQ grill. Chuck |
this may sound crazy but I've done it and it works. With the engine running and giving it revs spray water (use spray bottle) into the carb inlet. Don't let the engine die. You will get carbon blowing out the exhaust.
hibbert wrote: this may sound crazy but I've done it and it works. With the engine running and giving it revs spray water (use spray bottle) into the carb inlet. Don't let the engine die. You will get carbon blowing out the exhaust. But on a 2T, water on the crank, main bearings... not a good idea. |
Lambretta GP200, Vespa P200e, Motovespa do Brasil PX200E
Posts: 1218 Location: United States |
Ive always used a worn rounded screwdriver to scrape off hard stuff. Spray with carb cleaner a few times before and after. Then use fine steel wool and then polish to mirror finish with Autosol. If you run 100% synthetic after it will not coke up like mineral oil. Basically you'll just have a little oily film to wipe clean.
