03 Stella 2T TX200
03 Stella 2T TX200
Need photo of exact p200e cylinder head tightening ( torqueing ) sequence. I have had no luck finding one online !
Thanks !
w.c. Crying or Very sad emoticon
@mjrally avatar
@mjrally avatar
I don't have a photo but put the head on the studs, washers, nut, get a deep 13mm socket and finger tighten the nuts to get them started. Get your torque wrench set @ 16 ft/lbs and give a turn on the top left nut, then do a turn to the bottom right nut, turn upper right, turn bottom left. Restart the cycle with the upper left. The important thing is to torque down the head evenly, not one corner and then blast the other corner.
@dcunited4life avatar
No moar Vespas...sold them all
MJ is correct. Hand tighten first, then go around in a star pattern little by little with the torque wrench until the desired torque is achieved. After about 50-100 miles remove the shroud and recheck the torque.
@kulezi avatar
1980 P125X, 1978 P200 in pieces, 93 150 Exclusive (RIP)
@kulezi avatar
03 Stella 2T TX200
03 Stella 2T TX200
Thankyou !
w.c.
[ Time: 0.0092s ][ Queries: 3 (0.0034s) ][ live ][ 339 ][ ThingOne ]
