I have been working on a few things on my scoot including a Malossi 190 upgrade. I have also replaced all of the hub bearings and in order to get the clutch shaft out I took off the variator nut and outer half of the variator. I ordered a new nut but there is a delay in getting one so I thought I would just use the same nut (new last time).
I put loctite 262 on the thread and attempted to torque it up. It would not reach the target torque value and the more I torqued the more worried I got. I decided to bail at that point the whole thing felt like cheese. I removed the nut and it looks a bit worse for wear. Not overtly stripped but the thread looks a but mashed. On close inspection of the shaft there was a lot of older loctite residue in the thread. I wire brushed the shaft thread and it looks ok.
So I have decided to wait until the new nut arrives and cannot check out the Malossi Magic until then.
Anybody else done this?
