Help needed. I have a 2001 Vespa ET2 2 stroke with flooding problems.
First I will describe the problem, then I will state what I have done to attempt to fix it.
I recently bought this vespa with 485 miles on it. Very hard to start, usually takes 50 or so kicks with the throttle wide open, it then starts and once cleaned out, runs great! I can ride it for hours with no problems. If I turn it off, then wait 20 minutes or so, it will be flooded again and after 50 or so more kicks, it starts up, clean it out and ride again as long as you want. If parked overnight there will be a fairly large stain on the ground where fuel has leaked out onto the ground. It is coming from the airbox and running down the variator cover. I will lose 1/4 amount or more of fuel if it sits for a few days from leakage.
Runs great, idle is perfect, acceleration is awesome and top speed on flat ground is 43 MPH (70 KPH)
What I have done
1: cleaned the carb, checking the needle. no luck
2: Replaced the needle with a new one, no luck
3: Checked the fuel tap, was bad as fuel continually poured out of the clear fuel line once disconnected from the carb.
4: Replaced fuel tap with a new one, no luck
5: disconnected the clear fuel line from the carb, drained the gas out of the line, reconnected it and waited until the next morning, had fuel in it. (I never spun the motor over after clearing the fuel), Thought the fuel tap had a small leak, replaced it again, no luck
6: noticed there was no gasket on the fuel cap, Thinking that an air leak may cause fuel to flow from the bottom of the tank (Like a water bottle for a hamster), I made a gasket from an inner tube until I can find a new original one, No luck again
7:I also replaced the spark plug with a split fire (Nice plug!)
My next guess is to replace the float in the carb. What is it gong to take to stop this thing from flooding? It is a Weber carb. I am thinking either the surface that the needle seals on is bad, or the float is not raising up to shut off fuel flow. Maybe that's why it has low mileage, not running correctly from new?
Once started and cleaned out, it runs and idles great!
I have been kick starting it, the electric start does work, but I don't like to wear the battery down. I do use the electric start to re start it after sitting less that 10 minutes.
Any advice is appreciated. Fabio, especially yours
Second question is: There is a plastic shield around the cylinder, from that is a black rubber hose that goes within an inch or two from the carb (roughly 30mm diameter), but is not connected to anything, mine is missing, what does it do?
