My goal is to make it stronger up the hills, more accelration and top speed 65-70 km/h (40mph).
I will not go for long stroke 53mm crank and 125-130cc.
I have a Swedish imoprted vespa 50 smallframe 1966 doing 30km/h with following
specification:
50cc
10" wheels
Banana exhaust
Crankshaft (with minimal possible cavity, was to made them slower here)
Primary gear: 14/69-4,93 (also different on swedish imported than european 18/67)
3 gears
16/10 carburettor
Is following a ok setup?
75cc D.R Formula
4 gears
Carb 19/19 or 16/16
Primary 18/67: 3.72
Race crank 20mm spigot
Electronic ignition
I am unsure regarding primary gears. Maybe I would like to step up to 85 or 102cc in the future (I think 18/67 is good between 50-75cc). Would be nice to do that whitout splitting the engine again and changing both primarys.
I could buy a 24/72:3.0 kit which gives me possibility to change the small cog separately between
21/72:3.54, 22/72:3.27, 23/72:3.13, 24/72:3.0, 25/72:2.88
Can 50-75cc with primary 21/72:3.54 pull my weight 95kg (213lbs)
If I buy 18/67:3.72 there is only one more option and its 19/67:3.52
