@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Anyone know any good sources for "pink", "purple", "green/white" and "green/black" wire?
Selection is pretty limited at the usual car parts and hardware stores.
Running some new wires and trying to keep the colors as correct as possible so as not to drive me or a later owner batty downstream wondering what's what.
Thx.
parallelogramerist
parallelogramerist
Before I bring a car in to the junkyard, I usually cut out the wire harness and save it. The wires are higher quality than what you can get at a hardware store and there are multiple colored wires in the harness. Bring wire cutters with you to a U-PULL-IT junkyard.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Good suggestion, thanks. I'll hunt around.
@rob_hodge avatar
@rob_hodge avatar
you need to find a specialty supplier.
these are the guys i use.
http://electronicspartstore.com
[ Time: 0.0084s ][ Queries: 3 (0.0022s) ][ live ][ 343 ][ ThingOne ]
