Went for a run out on my GTS250 when i got home left the scoot ticking over while i was opening the garage door but literally within seconds of getting off the scoot it it spluttered & stalled and now it wont start,when i turn the key everything lights up as it should do and the fuel pump energizes but the engine won't turn over,not even a click on the starter motor.
I have disconnected the kill switch which was my first though but still nothing and have now got the battery on charge but i'm unable to tell how much voltage i have in the battery until i get a tester but the battery is less than two years old so i'm not convinced that's the problem.
I read on here that the battery needs a minimum 10v to start the engine but if that's the case would the lights,horn,oil light etc still work as if there wasn't a battery issue.
Thanks in advance...
