Now on to the problem. This is probably the last one, as everything else seems ok so far.
I've got a Vespa S50 small frame that I acquired recently from an owner that did not look after this beauty. After doing everything so far, which has mainly been cosmetic with some mechanical work, I get stuck at the starting part. I checked everything I could, and the problem is that it's not letting the fuel go from the tank to the carb. I've got a vacuum releasing the fuel normally, but it's not doing so. I've tried sucking trough the vacuum tube myself, and that releases the fuel. I tried doing this just before starting with the electric start, so it puts some fuel into the carb, and this starts the scooter right away. It only keeps going until the fuel in the carb runs out I'm guessing. After that it doesn't start until I do that again. I tried adjusting the screws on the carb but this doesn't seem to do anything. But to be honest, I'm not entirely sure I did that correct either, as I'm not 100% on what they do.
The air filter is not sealed around the carb. It's just put around it. Does this make a difference?
Thanks for reading this and any help would be seriously appreciated!
⚠️ Last edited by Messah on UTC; edited 1 time
