2008 Vespa S150
2008 Vespa S150
Recently acquired a 2008 Vespa S150. With the help of this great forum I was able to gather info on how to proceed with the LED conversion. Here are the end results.
Simple to do really.
Purchase 1157 3-wire bulb sockets for the front. Along with 1157 switchback style LED bulbs. Eliminate stock pod indicators. Cut off existing bulb sockets on white running lights. Wire in the new 3 wire ones. (If you need details on how to just ask!) I used the Signal Dynamics Dual load equalizer. It is super simple to wire in and tucks in perfectly. Rear bulbs were PY21W amber replacement LEDs. I though I would need another load equalizer for the rear but I guess the PY21Ws draw enough current and the blinking is fine. I am attaching some photos and videos.
2008 Vespa S150
2008 Vespa S150
Another photo
2008 Vespa S150
2008 Vespa S150
And another...
2008 Vespa S150
2008 Vespa S150
Update: Holes from old pod indicators fixed. For the small hole I used the color matched plugs from scooterwest. The bigger hole is just a plastic plug from Home Depot.
Also, how do I upload a video? Every time I try it tells me "no post mode selected"
@msprygada avatar
1979 P125x
@msprygada avatar
1979 P125x
You cannot post videos to MV. You have to post it on YouTube and then post the link or embed the video with a link.
2008 Vespa S150
2008 Vespa S150
@crazycarl avatar
@crazycarl avatar
What 1157 switchback bulbs did you use? I have the Scooterwest conversion for my GTS, but a bit disappointed in the light output of the running lights.
Yours look very bright.
[ Time: 0.0098s ][ Queries: 4 (0.0034s) ][ live ][ 341 ][ ThingOne ]
