Hi all hope your rides are safe and sweet. Ok a question, having no experience whatsoever how do I use a multimeter, specifically the settings as always many thanks in advance😎
It all depends on what you are intending to do with it hence the name "multimeter". What are you trying to test?
Here's a decent overview.
http://www.genebitsystems.com/david/MotorcycleElectrical/ Just an FYI- when I tried measuring household voltage I got arcing & damage to the leads! |
Posts: 8956 Location: Ashburn, Va. Home to the Internet |
Harvey wrote: Here's a decent overview. http://www.genebitsystems.com/david/MotorcycleElectrical/ Just an FYI- when I tried measuring household voltage I got arcing & damage to the leads! I suggest a Fluke 77, will last for ever and test just about anything you would want too. WOW, price on the Fluke 77 has gone way up. Had mine since 1990, but an employer paid for it |
Harvey wrote: Here's a decent overview. http://www.genebitsystems.com/david/MotorcycleElectrical/ Just an FYI- when I tried measuring household voltage I got arcing & damage to the leads! Some cheap multimeters don't have a fuse for the current setting, ones that don't have the fuse (usually 10 Amp) let the smoke out instead. |
paralla wrote: Harvey wrote: Here's a decent overview. http://www.genebitsystems.com/david/MotorcycleElectrical/ Just an FYI- when I tried measuring household voltage I got arcing & damage to the leads! Some cheap multimeters don't have a fuse for the current setting, ones that don't have the fuse (usually 10 Amp) let the smoke out instead. |
Skunkhome wrote: It all depends on what you are intending to do with it hence the name "multimeter". What are you trying to test? |
Posts: 5360 Location: Oceanside, CA |
Go on YouTube and search "How to use multimeter." Plenty of videos for digital and analog meters.
Posts: 4805 Location: Twin Cities, Minnesota |
Gcat wrote: Skunkhome wrote: It all depends on what you are intending to do with it hence the name "multimeter". What are you trying to test? Good luck & have fun! 8) |
2010 PIAGGIO BV 500ie Tourer
Posts: 4644 Location: Lakeshore, ON, CANADA-Capestang,FR |
There are a lot of auto ranging meters out there for under $50.00, with fuse protected amp and milliamp circuits.
The confusion comes when you have to change the positive (red) probe over to voltage. This can be forgotten when doing measurements from volts to amps. Please don't ask me how I know this. |
