@october avatar
64 allstate, 66 sprint, 74 primavera, 79 P125x
@october avatar
The p125x feels very unstable at speed.
I have new zippy 1's and new tubes, pressures are approx 19 front
36 rear...
If you take your hands off the grips, it pulls hard to the left...
Speeds over 60 are twitchy and scary.
@larrytsg avatar
1979 P200e
@larrytsg avatar
1979 P200e
Did this start after you got the new tires installed? Perhaps they're not balanced.
@ginch avatar
@ginch avatar
My friend has been riding his PX for 10 years plus. Recently whils following him on a ride I noticed his rear wheel looked wrong. When we fulled over it turned out he had put the wheel on backwards! It would be nice and easy if that was your problem.
Are Zippys directional? Worth a look I guess.
@october avatar
@october avatar
Yes,
They are directional... The tire goes one way for the rear, and the other way for the front...
I have them on my sprint, and it doesn't feel like this.
I wish I could explain it better...
It feels really squirrelly.
@championstuff avatar
1979 P125X
1979 P125X
Make sure that your steerer and handlebars are lined up perfectly. There is a hole below the headset that you can loosen and make them straight. Make sure you tighten the bolt enough when you are done or the from wheel will maneuver left or right free of the handlebars.
@rjy avatar
P125X/Apr 500/CH150/P200
@rjy avatar
What I want to know is how your getting up to 60 ?
1979 P125X
1979 P125X
I have a p125x and it barely goes over 45 with a tailwind.
@moto64 avatar
@moto64 avatar
That squirrelly handling can also be from steering that is too tight or bearings that need lubrication. I recently dealt with this on an Li125.
@chandlerman avatar
Innovator
242 Days Since Last Explosion
Innovator
@chandlerman avatar
Option A: "60 Indicated"
Option B: "60 KmPH"
Option C: Off a cliff
Clown emoticon
@october avatar
@october avatar
Polini 177 matched ports, and sip road...
62mph on gps
@rjy avatar
@rjy avatar
I think I need a new top end.
@october avatar
@october avatar
This is with the stock crank, and the 20/20 carb.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Hey Chris, the squirelliness could be a bent or incorrectly mounted wheel or hub. Get the wheels off the ground, spin them, and look for wobble or run out. Also check the tightness of the steering bearings. Pulling to the left sounds like a bad rear shock. Also, 36psi is way too much air.
62 mph.. woohoo. Polini delivers!
@october avatar
@october avatar
I was pretty pleased...
I'm sure it has more to offer, but I was still in the break in period, and it got sketchy with the questionable handling, so I backed off on the throttle.
The handling got scary, which to me isn't right. I would expect better handling characteristics from a p series over my sprint...
Lambretta GP200, Vespa P200e, Motovespa do Brasil PX200E
check for properly installed tires etc.
Are your motor mounts original and in good condition? badly worn mounts can cause it to pull
@october avatar
@october avatar
This was a barn find scooter with 630 miles on it...
Can the shock and or motor mounts go bad just from sitting?
@larrytsg avatar
1979 P200e
@larrytsg avatar
1979 P200e
Rubber degrades and hardens over time. We wouldn't ride on 35 year old tires. We wouldn't trust 35 year old tubes, so we should question all rubber parts on that scoot, including motor mounts, and shock mounts. Not to mention shocks front and back.
@pullmyfinger avatar
Some Vespa, some Yamaha, some Suzuki, some Kawasaki, some BMW, some Honda...
as already mentioned, your steering bearings are notched.
of course. As mentioned rubber dries out. Stock shocks suck even new !
@dcunited4life avatar
No moar Vespas...sold them all
I'd agree that 36psi is way too high of pressure for the tire. Try lowering it first and go from there. I ride about 25psi in mine.
@larrytsg avatar
1979 P200e
@larrytsg avatar
1979 P200e
The factory tire pressure is 17 front and 35 rear. It's on the sticker on the leg shield, and that's what I run.
35 rear when you have a passenger. Solo - 18 front, 26 rear.
[ Time: 0.0191s ][ Queries: 3 (0.0075s) ][ live ][ 343 ][ ThingOne ]
